coq-club - Re: [Coq-Club] Universal quantified hypothesis
chronological Thread
  • To: Cedric.Auger AT lri.fr
  • Cc: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Universal quantified hypothesis
  • Date: Mon, 25 Apr 2011 22:32:17 +0200 (CEST)
  • Importance: Normal
Dear Auger,
Although you did not understand what I asked (because I was unclear),
however your answer helped me to think better and to find a solution to my
problem.
Thanks anyway,
Marko Malikoviæ
> Le Mon, 25 Apr 2011 18:08:51 +0200 (CEST),
> Marko Maliković
> <marko AT ffri.hr>
>  a Ã©crit :
>> Hello all,
>> Perhaps the following question is naive but I do not find a solution:
>> Is it possible context, which contains a hypothesis with dependent
>> product, for example:
>> H : forall A : Prop, A
>>  goal
>> into the context with quantifier free hypothesis:
>> A : Prop
>> H : A
>>  goal
>> Are the above two proofs equivalent at all?
>> Thanx and greetings,
>> Marko Maliković
> Your question is not clear, but your first case is rather a proof of
> "(forall A, A) -> goal" (which is trivial to prove, just apply H), and
> the second is rather a proof of "forall A, A -> goal" (which may be
> non trivial or even false, depending on "goal").
> So, as the things to prove are different, I guess that knowing if the
> proofs are equivalent has no real meaning.
> What is equivalent is rather:
> A: Prop
> H: A
> goal
> A: Prop
> forall (H:A) -> goal
> " and
> forall (A:Prop) (H:A) -> goal
> but I guess you already know it
Dr. Sc. Marko Malikoviæ
Filozofski fakultet
Sveuèili¹te u Rijeci
Ph.D. Marko Malikoviæ
Faculty of Humanities and Social Sciences
University of Rijeka, Croatia
marko AT ffri.hr
http://www.ffri.hr/~marko
