coq-club - Re: [Coq-Club] Proving equality of coinductives
chronological Thread
  • To: Daniel Schepler <dschepler AT gmail.com>
  • Cc: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Proving equality of coinductives
  • Date: Tue, 26 Apr 2011 18:34:16 +0100
Hi Daniel,
this is coinduction and is not provable in Coq - this is basically the same
issue as for functional extensionality. If you have functional extensionality
you can encode coinductive types so that coinduction is provable but this may
be a bit inconvenient. The extensionality axiom can be eliminated as we have
described a few years ago in our "Observational Type Theory, now" paper which
appeared in PLPV 08.
Cheers,
Thorsten
On 26 Apr 2011, at 17:56, Daniel Schepler wrote:
> I was looking at proving monad properties of:
> CoInductive Coroutine (X:Type) : Type :=
> | coroutine_return : X -> Coroutine X
> | yield_with_continuation : Coroutine X -> Coroutine X.
> Implicit Arguments coroutine_return [[X]].
> Implicit Arguments yield_with_continuation [[X]].
> I was eventually able to prove the necessary identities, assuming the axiom:
> CoInductive coroutine_eq {X} : Coroutine X -> Coroutine X -> Prop :=
> | coroutine_return_eq: forall x0:X,
>    coroutine_eq (coroutine_return x0) (coroutine_return x0)
> | yield_eq: forall x y:Coroutine X, coroutine_eq x y ->
>    coroutine_eq (yield_with_continuation x) (yield_with_continuation y).
> Axiom coroutine_eq_eq: forall {X} (x y:Coroutine X),
>  coroutine_eq x y -> x = y.
> My question is: is there any way to prove that axiom?  Maybe using a single
> axiom which would also imply corresponding statements for Stream,
> PossiblyTerminatingStream, InfinitelyBranchingBinaryTree, etc.?
> Daniel Schepler
