coq-club - Re: [Coq-Club] void : Type
chronological Thread
  • To: Gert Smolka <smolka AT ps.uni-saarland.de>, Coq-Club <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] void : Type
  • Date: Mon, 2 May 2011 02:34:53 -0700 (PDT)
  • Domainkey-signature: a=rsa-sha1; q=dns; c=nofws; s=s1024; d=yahoo.com; h=Message-ID:X-YMail-OSG:Received:X-Mailer:References:Date:From:Subject:To:In-Reply-To:MIME-Version:Content-Type; b=a2Pstxc4ZNlNQPB4y0v5ionT33pOIU1KzGqWq9JPzt9uMo2pOzHWdm03S5hZVKybowV55gkNFhdf3aX6r8aR74Yam88mTKaXYaWU4c8GWCG+5jPk57TZDrO9il4YoUyrb63v0NTxrqpzyd/ml5asQ7aBvD9677flMYLWk7LcWZI=;
The responses so far provide good answers to question 2, but not question 1.
Why does Coq ignores the explicit ": Type" annotation?
Here is a way to force zero, one and two to be in one of the Type universes.
Is there a simpler way?
Inductive zero : Type := .
Check zero.
===> zero : Prop
Definition zeroT : Type := zero.
Check zeroT.
===> zeroT : Type
- Chad
To: Coq-Club <coq-club AT inria.fr>
Sent: Mon, May 2, 2011 9:17:59 AM
Subject: [Coq-Club] void : Type
Check zero.
===> zero : Prop
Inductive one : Type := O : one.
Check one.
===> one : Prop
Inductive two : Type := A : two | B : two.
Check two.
===> two : Set
1. Why does Coq ignore my wish to place the types
in one of the universes Type ranges over?
2. Why are zero and one put into Prop while
two is put into Set?
-- Gert
