- To: AUGER Cedric <Cedric.Auger AT lri.fr>
- Cc: coq-club AT inria.fr
- Subject: Re: [Coq-Club] transparent assert?
- Date: Mon, 2 May 2011 22:05:27 -0700
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:sender:in-reply-to:references:date :x-google-sender-auth:message-id:subject:from:to:cc:content-type :content-transfer-encoding; b=W59I6+iCPlVOeKRwCOBp5dXUNkRW11+7N2sfZbERjMxL2kJprnwx8tC6egp0fdVWS4 a1hb69hOzwrfrDZjAamoSb4i+ARxzeWX8WFQgTJpl/1U1+tvAZu38ZdC/qKmodsnsXPW s3gzNCmv2ltif3gVBGswcIvSP6yp4XAdFnSI0=
Thanks for your reply!
On Mon, May 2, 2011 at 3:39 PM, AUGER Cedric
wrote:
> That is a feature I would also like to have (although i consider it to
> be dirty, as transparent terms should be written litteraly IMO).
Even ones that would end up being pages and pages long, but can be
defined quite concisely and comprehensibly using tactics?
> There are 3 possible other workarounds I know of:
> * use of "set (x:=…)", but you need to be able to provide the whole term
> * use of existential tactics, so you don't build "x" explicitely.
> In this case, it should lead to "eexists." or "esplit." or
> "econstructor.", according to the one you prefer to use instead of
> "exists x0." (and no assert at all), then "instantiate", "eauto",
> "eassumption", … will probably be usefull.
I don't think either of these will work for me, because I don't have a term to
pass to "set" or "instantiate". If I knew the term, I could just
write "exists ..."
to begin with rather than wanting to use tactics.
> * find a very precise specification "Q" of your wished "X" then prove
> "{x|Q x}" and then continue using your hypothesis.
It's not clear to me how that will help, because now I'm stuck trying
to prove { x:X & Q x } instead of { x:X & P x }, and I have exactly the
same problem! But maybe I misunderstood.
Thanks!
Mike
- [Coq-Club] transparent assert?, Michael Shulman
- Re: [Coq-Club] transparent assert?,
AUGER Cedric
- Re: [Coq-Club] transparent assert?, Michael Shulman
- Re: [Coq-Club] transparent assert?, Arnaud Spiwack
AUGER Cedric
