coq-club - Re: [Coq-Club] hostile plugin hidden inside big archive with proofs can subvert
chronological Thread
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] hostile plugin hidden inside big archive with proofs can subvert
  • Date: Mon, 09 May 2011 17:20:39 +0200
On 05/05/2011 11:07 AM, Andreas Bogk wrote:
Excerpts from guninski's message of Mi Mai 04 13:50:13 +0200 2011:
   Proof.
     external "/bin/sh" "ESCAPE_SEQ; write_vo_proof; nicely_kill_coq ;" True.
     (* this invokes /bin/sh. suited for formal software verification *)
   Qed.
FWIW, I think that this "external" feature, as well as the loading of
arbitrary
plugins, are indeed a problem.
external is supposed to return either a proof term or a tactic to be applied on the goal. You can disrupt the execution flow as Georgi did and forge object files, but the checker (and an inspection of the object file) will detect that.
Coq is more and more being used for software
engineering for critical systems.
Yes, been there, done that...
There's a huge benefit in being able to
specify desired behaviour of subsystems formally, and have the author of the
subsystem prove that his implementation fulfills the specification.  The
ability
to break proof checking by the tricks demonstrated mean we're back at having
to
read every single line of code of the subsystem, instead of being able to just
read the specification and leave the details to the proof checking engine.
I think you are slightly rigorist here (please don't take that personally nor negatively). Having well-behaved subcomponents is clearly a good practice but (1) it may prevent you from using incomplete though effective proof techniques, and (2) it doesn't give the highest levels of confidence on its own.
Look at Chris Casinghino's and Brian Aydemir's proof of Fermat's theorem (Stéphane gave a link). You could formalise the syntax thoroughly and being convinced you understand every single detail of the syntax, and still fall in their trap. Whatever the syntax, you'll always find an illusionist to trick you.
The best defense against illusion is to have several viewpoints. That's what we intend to provide with the checker and the missing tool: a .vo file explorer.
My suggestion would be:
  * Remove the "external" feature, or make it optional, with "turned off"
being
    the default
  * Split load paths for .vo files and coq plugins, make plugin load path
    default to system directories only, inhibit manipulation of plugin
    load path from within .v files.
This is somehow a packaging policy that you may want to follow in a skeptical mode, but it seems dangerous to me to rely only on such techniques because it's hard to guarantee that there is no similar trapdoor in the toplevel.
Bruno Barras                    Typical team - INRIA Saclay
LIX - Ecole Polytechnique       91128 Palaiseau Cedex - France
Tel: +33 1 69 33 40 57          Fax: +33 1 69 33 30 14
