- To: guninski AT guninski.com, coq-club AT inria.fr
- Subject: Re: [Coq-Club] "Anomaly" when doing Load self.v
- Date: Wed, 11 May 2011 12:51:11 -0700 (PDT)
- Domainkey-signature: a=rsa-sha1; q=dns; c=nofws; s=s1024; d=yahoo.com; h=Message-ID:X-YMail-OSG:Received:X-Mailer:References:Date:From:Subject:To:In-Reply-To:MIME-Version:Content-Type; b=N9+oY7LNUVQFPhumrMZLTYjLZFn6HhIpxNSsBxQZFDJjn3zkLJRSbYwvFpgeIjwSImPdOTuWdxaO+c/8GoKu7UwQ395wnlTL5VVfmAOSfN6xliUzug7bLOf/FYrNwPE/6YO1Ct2H3+FCeQPjfR8ycixpS3UxRwy3JnKJtUw/oH8=;
> please excuse my dumbness:
> is normal behavior invoking a lemma to break the future proof of the true
>fact:
> "True -> True" (implication).
Which lemm? False_ind?
> the lemma magically changes the coq subgoal from True to False after
> invoking
> the lemma. (if i can change it the other way, i will have a fake proof).
> is there some theoretical justification the subgoal to be changed to False
at
> will?
Yes. Given false, you can prove anything. It's a plausible strategy for
proving a goal to say "I will first prove False (show that the hypotheses
are inconsistent), and then use that to trivially prove the current goal."
Depending on the lemma or tactic you use, the second step might be handled
automatically, leaving you with just the subgoal of proving the first
part.
It's not surprising that there are some strategies you just can't use to
finish certain proofs. In particular, using "clear" to throw away hypotheses
will quickly make most goals impossible.
Coq can't always warn you that making a step you request leads
into such a dead end. A common case is trying to prove something
by induction, and eventually realizing that you actually needed to generalize
the original goal before the inductive proof can go through.
Brandon
- [Coq-Club] "Anomaly" when doing Load self.v, guninski
- Re: [Coq-Club] "Anomaly" when doing Load self.v, Brandon Moore
- Re: [Coq-Club] "Anomaly" when doing Load self.v, Hugo Herbelin
