- From: Gregory Malecha <gmalecha AT eecs.harvard.edu>
- To: Vladimir Voevodsky <vladimir AT ias.edu>
- Cc: Maxime Dénès <Maxime.Denes AT inria.fr>, Coq-Club Club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] "Unset boxed definitions"
- Date: Sat, 21 May 2011 12:10:40 -0700
I believe that ": core" means "in the core hint database.
On Sat, May 21, 2011 at 11:31 AM, Vladimir Voevodsky <vladimir AT ias.edu> wrote:
Thanks! I am trying to understand the standard library and it is full of commands which I never heard about. Â Here is another question:
in [ Hint Unfold not: core. ] what does [ ... : core ] do ?? (I know that [ core ] is one of the three main notation scopes but [ not ] is not a notation .... )
Vladimir.
On May 21, 2011, at 2:12 PM, Maxime Dénès wrote:
> Dear Vladimir,
> Boxed definitions were used to avoid early unfolding of constants by Coq's VM (if I remember correctly), and are now deprecated (I think these directives are interpreted as noop by the current trunk), hence probably the lack of documentation.
> Hope it helps.
> Maxime.
> On 21/05/2011 20:09, Vladimir Voevodsky wrote:
>> What does this command do? It is not in the command index of the reference manual.
>> Thanks!
>> Vladimir.
gregory malecha
- [Coq-Club] "Unset boxed definitions", Vladimir Voevodsky
- Re: [Coq-Club] "Unset boxed definitions",
Maxime Dénès
Vladimir Voevodsky
- Re: [Coq-Club] "Unset boxed definitions", Gregory Malecha
- Re: [Coq-Club] "Unset boxed definitions", julien forest
Vladimir Voevodsky
Maxime Dénès
