coq-club - Re: [Coq-Club] Stuck on a proof of div2 (n + n) = n.
chronological Thread
  • From: Pierre Casteran <pierre.casteran AT labri.fr>
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Stuck on a proof of div2 (n + n) = n.
  • Date: Sat, 21 May 2011 21:37:55 +0200
Hello,
 You can easily finish you proof with a simple lemma:
Lemma div2_le : forall n, div2 n <= n.
destruct n.
 simpl;auto with arith.
apply lt_le_weak. apply lt_div2. auto.
auto with arith.
Qed.
Then the last case  of your proof is:
(* case S (S m) *)
apply le_lt_trans with (S (S m)).
apply div2_le.
auto.
Qed.
Pierre
Quoting frank maltman
<frank.maltman AT googlemail.com>:
More in the same vein, unfortunately.
I know intuitively that the only time div2 n < n does not
hold is when n = 0. Unfortunately, I'm unable to work out
how to use the fact that m < n so therefore n /= 0:
Lemma div2_lt_trans : forall m n, m < n -> Div2.div2 m < n.
Proof.
intros m n HMN.
induction m using Div2.ind_0_1_SS.
(* case 0 *)
simpl. assumption.
(* case 1 *)
simpl. auto with arith.
(* case S (S m) *)
simpl. assert (m < n) by omega. apply IHm in H.
I find myself stuck here:
1 subgoal
m : nat
n : nat
HMN : S (S m) < n
IHm : m < n -> Div2.div2 m < n
H : Div2.div2 m < n
______________________________________(1/1)
S (Div2.div2 m) < n
I know S (S m) < n, therefore I know m < n.
I know div2 m < m, therefore I know ... tentatively ...
that S (Div2.div2 m) < n...
Presumably there's a better way to go about this?
