coq-club - Re: [Coq-Club] is it normal [firstorder] to hang on simple testcase?
chronological Thread
  • To: david.baelde AT ens-lyon.org
  • Cc: Pierre Corbineau <Pierre.Corbineau AT imag.fr>, coq-club AT inria.fr
  • Subject: Re: [Coq-Club] is it normal [firstorder] to hang on simple testcase?
  • Date: Wed, 25 May 2011 18:47:51 +0300
  • Header: best read with a sniffer
hi,
what do you mean by "stack overflow" - too much recursion resulting in
stack exhaustion or smashing the stack due to overflow?
on latest coqtop your testcase would apear to corrupt the stack
 if gdb is correct:
gdb coqtop
<your code
Program received signal SIGSEGV, Segmentation fault.
0x00007ffff68886ab in camlCcalgo__find_aux_1050 ()
   from /home/blah/local/lib/coq/plugins/cc/cc_plugin.cmxs
   (gdb) bt
   #0  0x00007ffff68886ab in camlCcalgo__find_aux_1050 ()
      Cannot access memory at address 0x7fffff5feff0
if the last message is real it is hacker's dream (not counting the plugin
feature of coq) :)
On Wed, May 25, 2011 at 05:33:21PM +0200, David Baelde wrote:
> OCaml applications compiled to native code may cause segmentation
> faults as a result of stack overflows. I have experienced this,
> including with Coq, for which I have a file that causes sigsegv or
> stack overflow depending on the coq/ocaml versions:
> Require Export Bvector.
> Notation BVfalse := (Vconst bool false).
> Goal forall n (a b : bool) (v : Bvector n),
>       Vcons _ a n v = Vcons _ b n (BVfalse n) -> v = BVfalse n.
> Proof.
>   intros.
>   assert (v = BVfalse n) by congruence.
> Cheers,
> David
