coq-club - Re: [Coq-Club] applying a function definition
chronological Thread
  • To: Guillaume Brunerie <guillaume.brunerie AT gmail.com>
  • Cc: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] applying a function definition
  • Date: Sat, 28 May 2011 10:18:19 -0500
  • Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=subject:mime-version:content-type:from:in-reply-to:date:cc :message-id:references:to:x-mailer; b=MQY5v1ltMdYhNBW89d6kZmEpxhH40OU+2vLIiruLgq2T5VMqTPCARsM9ezoigfCrC3 9o9LKbXOZiGWDDMunVk8fYUWb11Hk5bBpKKRQQFzkcBiM0yOb+UBI27XT5o8We6fq3Qg /K+c2A2eSPrYRgQvsDXvF8VgiPq+eTum8Euv8=
Thanks a lot, the following did it!
Lemma po_ip : forall n:B, n<>e -> p (o n) = i (p n).
Proof.
intros n H.
simpl.
Show.
case_eq n.
firstorder.
firstorder.
intros.
firstorder.
Qed.
I am still puzzled why after simpl I get:
  n : B
  H : n <> e
   match n with
   | e => e
   | o _ => i (p n)
   | i _ => i (p n)
   end = i (p n)
where the underscores indicate that Coq is ignoring or forgetting the actual argument - this does not seem equivalent with the definition of p. Impressed that magic works:-), but is there anything that could make the proof obtained by the sequence of tactics somewhat human readable - for instance I would be curious to see what firstorder did "under the hood".
Paul
On May 28, 2011, at 9:38 AM, Guillaume Brunerie wrote:
2011/5/28 <paul.tarau AT gmail.com>
I have defined a simple predecessor function "p" for bijective base-2
arithmetic on type B as:
Inductive B : Set :=
|  e : B
|  o : B -> B
|  i : B -> B.
Delimit Scope b_scope with B.
Bind Scope b_scope with B.
Arguments Scope o [b_scope].
Arguments Scope i [b_scope].
Fixpoint p (x : B) : B :=
 match x with
 | e => e
 | o e => e
 | o a => i (p a)
 | i a => o a
 end.
Eval compute in p (p (i (i (o e)))).
(* The definition seems accepted and "Eval compute" works as expected *)
(* I would like to apply the definition of p and prove the following lemma. *)
Proof.
intros n H.
Show.
(* Unfortunately none of the tactics I have tried work at this point and the
ref. manual does not seem to have one that does allows you to a apply a
function definition directly (or maybe it is there and I could not find it?).
What should I do next to convince Coq to use the option o n => i (p a) in the
definition of p to prove the lemma?
Thanks,
Paul
You can use the tactic 'simpl', which will unfold the definition of p.
After that, the tactic 'case_eq' will allow you to prove the result for every case, while retaining the value of n (try 'case' instead to see what I mean).
And 'firstorder' will then do the job.
Guillaume
