- To: Gregory Malecha <gmalecha AT eecs.harvard.edu>
- Cc: Coq Club <coq-club AT inria.fr>, Jesper Bengtson <jebe AT itu.dk>
- Subject: Re: [Coq-Club] Rewriting with Existentials
- Date: Tue, 31 May 2011 10:00:43 +0200
Hi Gregory
On Tue, May 31, 2011 at 03:20, Gregory Malecha
wrote:
> Is there any way to tell autorewrite to treat existentials as "atomic," i.e.
> not be able to expand them arbitrarily?
We've had the same type of problem in our development recently. The
quick-fix was to do pre- and post-processing steps to make the
existentials opaque. Here's your code with this hack applied:
Require Import Plus.
Ltac ugly_evar_hack_create :=
repeat (match goal with
[ |- context[?x]] => is_evar x; let l := fresh "l" in
remember x as l
end).
Ltac ugly_evar_hack_restore :=
| [H : (?l = ?evar) |- ?p] => is_evar evar; subst l
end).
Hint Rewrite <- plus_assoc : test.
Goal exists x, x + 0 = x.
eexists.
do 3 rewrite <- plus_assoc. (** produces a bunch of existentials **)
ugly_evar_hack_create; autorewrite with test; ugly_evar_hack_restore.
These tactics can certainly be made more robust and easy to work with.
And I hope somebody else has a better solution.
Cheers,
Jonas
- [Coq-Club] Rewriting with Existentials, Gregory Malecha
- Re: [Coq-Club] Rewriting with Existentials, Jonas B. Jensen
