- From: wataru yamazaki <wataru.yamazaki.nullptr AT gmail.com>
- To: coq-club AT inria.fr
- Subject: [Coq-Club] Instance declarations causes infinite loop
- Date: Tue, 14 Jun 2011 13:00:19 +0900
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:date:message-id:subject:from:to:content-type :content-transfer-encoding; b=qT2FZ275vNVMNmj46iac6U6mxyI8pi5LuLYj6BlhT6ksvyGZOV/jjeDUsNT1vrc934 8TkTXDAK5eebP0anAkOuUTd+6nUiGhtMK4XWn7PrXrpdIaSDZJbdYNYmDNBQa9Itxknu mBc+yEAH1d9dEOUXTEC7tytbRDbQt5khqUQCg=
The following code gets stuck in an infinite loop at last instance
decralation on coq-v8.3pl2.
(* code *)
Require Import Setoid.
Require Import SetoidClass.
Section Monoid.
Set Implicit Arguments.
Set Strict Implicit.
Unset Automatic Introduction.
Class Monoid_struct (S:Type) :=
{ dot : S -> S -> S
; mon_oid :> Setoid S
; dot_assoc : forall x y z, dot (dot x y) z ==dot x (dot y z)
; unit : S
; unit_id_l : forall y, dot unit y == y
; unit_id_r : forall x, dot x unit == x
Record Monoid :=
{ Mset :> Type
; monoid_struct :> Monoid_struct Mset
Instance Monoid_setoid : Setoid Monoid :=
{ equiv x y := Mset x = Mset y }.
split; unfold Reflexive, Symmetric, Transitive; auto.
intros x y z H H0.
transitivity y; auto.
Qed.
End Monoid.
Section MonoidHom.
Infix "*" := dot (at level 40).
Notation "'å'" := unit.
Class Monoid_mor_struct {A B:Type} (M:Monoid_struct A) (M':Monoid_struct B) :=
{ homM : A -> B
; homM_morphism :> forall a,
Proper (equiv)(homM a )
; hom_distr : forall x y:A, homM (x * y) == homM x * homM y
; hom_id : homM å == å
End MonoidHom.
Section Monoid_cat.
Variable A B:Type.
Let Mmor (M M':Monoid) : Type.
intros.
eapply Monoid_mor_struct.
apply M.
apply M'.
Defined.
Instance Monoid_equiv : Setoid Monoid.
Notation "# f" := (homM (Monoid_mor_struct:=f)) (at level 0).
Definition Mmor_equiv (M M':Monoid) : relation (Mmor M M') :=
fun (f g:Mmor M M') => (forall (x:M), #f x = #g x).
Program Instance Mmor_oid M M' : Setoid (Mmor M M') :=
{ equiv := @Mmor_equiv M M' }.
Next Obligation.
unfold Mmor_equiv.
split.
intros f g.
reflexivity.
intros f g H x.
symmetry.
apply H.
intros f g h H0 H1 x.
transitivity (#g x).
apply H0.
apply H1.
Qed.
Class Cat_s (obj:Type)(mor: obj -> obj -> Type) := {
mor_oid:> forall a b, Setoid (mor a b);
comp: forall {a b c},
mor a b -> mor b c -> mor a c;
comp_oid:> forall a b c,
Proper (equiv ==> equiv ==> equiv) (@comp a b c)
Instance MON_struct : Cat_s (obj:=Monoid) (fun M M':Monoid =>
Monoid_mor_struct M M') :=
{ mor_oid := Mmor_oid }.
(* end code*)
If I use svn-head version of coqtop, this code dont't get infinite loop.
But head version has many other probles, so I want use stable version.
When I inturrupt this loop on coqtop, coqtop says,
In nested Ltac calls to "proper_reflexive", "class_apply" and
"autoapply c using typeclass_instances" (expanded to
"autoapply reflexive_proper using typeclass_instances"), last call failed.
How to declare Instance 'MON_struct' with avoiding infinite loop on coq
8.3pl2 ?
Thank you.
wataru
- [Coq-Club] Instance declarations causes infinite loop, wataru yamazaki
