coq-club - Re: [Coq-Club] "Function {measure}" and induction principles
chronological Thread
  • From: David Pichardie <david.pichardie AT inria.fr>
  • To: Chris Casinghino <chris.casinghino AT gmail.com>
  • Cc: Coq Club <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] "Function {measure}" and induction principles
  • Date: Wed, 29 Jun 2011 09:45:59 +0200
Hi Chris,
Cedric already gives the trick.
If you want to obtain exactly the induction principle you want about go_right
(and not its variation proposed by Cedric), here is a modest solution.
David.
Require Import ZArith.
Require Import Recdef.
 Inductive Foo : Type :=
   | FooBase : Foo
   | FooTwo  : Foo -> Foo -> Foo.
 Fixpoint size (f : Foo) : nat :=
   match f with
   | FooBase      => 0
   | FooTwo f1 f2 => 1 + (size f1) + (size f2)
   end.
Function go_right (f : Foo) {measure size f} : Foo :=
   match f with
   | FooBase      => FooBase
   | FooTwo f1 f2 =>
     go_right f2
   end.
   intros; simpl; omega.
Defined.
Definition trick {A B:Type} (a:A) (b:B) := b.
Function go_right' (f : Foo) {measure size f} : Foo :=
  match f with
    | FooTwo f1 f2 =>
      trick (go_right' f1) (go_right' f2)
  end.
Defined.
Lemma go_right'_is_go_right : forall f,
  go_right f = go_right' f.
Proof.
  intros f.
  functional induction (go_right f); rewrite go_right'_equation; auto.
Qed.
Lemma go_right_rect_v2
     : forall P : Foo -> Foo -> Type,
       (forall f : Foo, f = FooBase -> P FooBase FooBase) ->
       (forall f0 f1 f2 : Foo,
        f0 = FooTwo f1 f2 ->
        P f1 (go_right f1) ->
        P f2 (go_right f2) ->
        P (FooTwo f1 f2) (go_right f2)) ->
       forall f1 : Foo, P f1 (go_right f1).
Proof.
  intros.
  rewrite go_right'_is_go_right.
  apply go_right'_rect; auto.
  intros;
    repeat rewrite <- go_right'_is_go_right;
    unfold trick; eapply X0;
    repeat rewrite go_right'_is_go_right; eauto.
Qed.
