coq-club - Re: [Coq-Club] implicit argument in identity
chronological Thread
  • To: Pierre Courtieu <Pierre.Courtieu AT cnam.fr>
  • Cc: Coq-Club Club <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] implicit argument in identity
  • Date: Thu, 30 Jun 2011 15:32:52 -0400
Thanks!
My problem was  that in the html version of Coq.Init.Datatypes which is
linked with standard Coq documentation there is no  Set Implicit Arguments
command .
V.
On Jun 30, 2011, at 3:02 PM, Pierre Courtieu wrote:
> Hello Vladimir,
> No, if you play the script of Datatype.v until the definnition of
> identity and use [About identity] you will see that the argument is
> already implicit. Actually this is probably due to the global [ Set
> Implicit Arguments ] at the beginning of the same file.
> Best regards,
> Pierre
> 2011/6/30 Vladimir Voevodsky
> <vladimir AT ias.edu>:
>> Hello,
>> does anybody know where the first ( type ) argument of [ identity ] is
>> declared to be implicit ?
>> [ identity ] itself is defined in Coq.Init.Datatypes but there the first
>> argument is explicit.
>> Thanks!
>> Vladimir.
