- To: coq-club AT inria.fr
- Cc: Tom Prince <tom.prince AT ualberta.net>
- Subject: [Coq-Club] [PATCH 1/3] Add option 'Unset Printing Records'.
- Date: Sat, 2 Jul 2011 18:03:23 -0600
This option disables the use of the '{| field := ... |}' notation
when printing.
Signed-off-by: Tom Prince
CHANGES | 1 +
doc/refman/RefMan-ext.tex | 5 +++++
interp/constrextern.ml | 2 +-
lib/flags.ml | 2 ++
lib/flags.mli | 1 +
test-suite/output/Record.out | 8 ++++++++
test-suite/output/Record.v | 11 +++++++++++
tools/coq-syntax.el | 1 +
toplevel/ide_slave.ml | 1 +
toplevel/vernacentries.ml | 8 ++++++++
10 files changed, 39 insertions(+), 1 deletions(-)
create mode 100644 test-suite/output/Record.out
create mode 100644 test-suite/output/Record.v
diff --git a/CHANGES b/CHANGES
index 54b4430..649c43f 100644
--- a/CHANGES
+++ b/CHANGES
@@ -18,6 +18,7 @@ Specification language and notations
applications (use eta expanded form with explicit { } instead).
- Added support for recursive notations with binders (allows for instance
to write "exists x y z, P").
+- Structure/Record printing can be disable by "Unset Printing Records".
Tactics
diff --git a/doc/refman/RefMan-ext.tex b/doc/refman/RefMan-ext.tex
index 6801533..182a509 100644
--- a/doc/refman/RefMan-ext.tex
+++ b/doc/refman/RefMan-ext.tex
@@ -200,6 +200,11 @@ Definition b := {| x := 5; y := 3 |}.
Definition c := {| y := 3; x := 5 |}.
\end{coq_example}
+This syntax can be disabled for printing by
+\begin{quote}
+{\tt Unset Printing Records.}
+\end{quote}
This syntax can also be used for pattern matching.
\begin{coq_example}
diff --git a/interp/constrextern.ml b/interp/constrextern.ml
index 91ae112..f23f975 100644
--- a/interp/constrextern.ml
+++ b/interp/constrextern.ml
@@ -550,7 +550,7 @@ let rec extern inctx scopes vars r =
extern_args (extern true) (snd scopes) vars args subscopes in
begin
try
- if !Flags.raw_print then raise Exit;
+ if !Flags.raw_print or not !Flags.record_print then raise
Exit;
let cstrsp = match ref with ConstructRef c -> c | _ -> raise
Not_found in
let struc = Recordops.lookup_structure (fst cstrsp) in
let projs = struc.Recordops.s_PROJ in
diff --git a/lib/flags.ml b/lib/flags.ml
index 45ca062..54bfb40 100644
--- a/lib/flags.ml
+++ b/lib/flags.ml
@@ -34,6 +34,8 @@ let load_proofs = ref Lazy
let raw_print = ref false
+let record_print = ref true
let allow_inconsistent_universes = ref false
(* Compatibility mode *)
diff --git a/lib/flags.mli b/lib/flags.mli
index a07612c..080ac7f 100644
--- a/lib/flags.mli
+++ b/lib/flags.mli
@@ -24,6 +24,7 @@ type load_proofs = Force | Lazy | Dont
val load_proofs : load_proofs ref
val raw_print : bool ref
+val record_print : bool ref
val allow_inconsistent_universes : bool ref
diff --git a/test-suite/output/Record.out b/test-suite/output/Record.out
new file mode 100644
index 0000000..a3c63ea
--- /dev/null
+++ b/test-suite/output/Record.out
@@ -0,0 +1,8 @@
+{| field := 5 |}
+ : test
+{| field := 5 |}
+ : test
+build 5
+ : test
+build 5
+ : test
diff --git a/test-suite/output/Record.v b/test-suite/output/Record.v
index 0000000..4ae4338
--- /dev/null
+++ b/test-suite/output/Record.v
@@ -0,0 +1,11 @@
+Record test := build { field : nat }.
+Set Printing Records.
+Check build 5.
+Check {| field := 5 |}.
+Unset Printing Records.
+Check build 5.
diff --git a/tools/coq-syntax.el b/tools/coq-syntax.el
index 5b88f6a..bc0e18e 100644
--- a/tools/coq-syntax.el
+++ b/tools/coq-syntax.el
@@ -497,6 +497,7 @@
("Set Printing Synth" nil "Set Printing Synth" t
"Set\\s-+Printing\\s-+Synth")
("Set Printing Wildcard" nil "Set Printing Wildcard" t
"Set\\s-+Printing\\s-+Wildcard")
("Set Printing All" "sprall" "Set Printing All" t
"Set\\s-+Printing\\s-+All")
+ ("Set Printing Records" nil "Set Printing Records" t
"Set\\s-+Printing\\s-+Records")
("Set Hyps Limit" nil "Set Hyps Limit #." nil "Set\\s-+Hyps\\s-+Limit")
("Set Printing Coercions" nil "Set Printing Coercions." t
"Set\\s-+Printing\\s-+Coercions")
("Set Printing Notations" "sprn" "Set Printing Notations" t
"Set\\s-+Printing\\s-+Notations")
diff --git a/toplevel/ide_slave.ml b/toplevel/ide_slave.ml
index 3aa2744..dfabfb1 100644
--- a/toplevel/ide_slave.ml
+++ b/toplevel/ide_slave.ml
@@ -32,6 +32,7 @@ let coqide_known_option table = List.mem table [
["Printing";"Synth"];
["Printing";"Notations"];
["Printing";"All"];
+ ["Printing";"Records"];
["Printing";"Existential";"Instances"];
["Printing";"Universes"]]
diff --git a/toplevel/vernacentries.ml b/toplevel/vernacentries.ml
index 769f101..2c40974 100644
--- a/toplevel/vernacentries.ml
+++ b/toplevel/vernacentries.ml
@@ -928,6 +928,14 @@ let _ =
let _ =
declare_bool_option
{ optsync = true;
+ optname = "record printing";
+ optkey = ["Printing";"Records"];
+ optread = (fun () -> !Flags.record_print);
+ optwrite = (fun b -> Flags.record_print := b) }
+let _ =
+ declare_bool_option
+ { optsync = true;
optname = "use of virtual machine inside the kernel";
optkey = ["Virtual";"Machine"];
optread = (fun () -> Vconv.use_vm ());
1.7.5.2
- [Coq-Club] [PATCH 1/3] Add option 'Unset Printing Records'., tom . prince
