- To: Paolo Herms <paolo.herms AT cea.fr>
- Cc: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Identity Coercions and Uniform Inheritance Condition
- Date: Thu, 21 Jul 2011 13:28:55 +0200
Le Wed, 20 Jul 2011 12:59:17 +0200,
Paolo Herms
a écrit :
> Hello,
> reference manual section 17.4 [1] claims that Identity Coercions
> could be "used to go around the uniform inheritance condition". It
> doesn't give an example and I don't understand how. Here's what I
> tried:
> Parameter C : Type -> Type.
> Parameter D : Type -> Type -> Type.
> Parameter f : forall A B, C A -> D A B.
> Fail Coercion f: C>->D. (* obviously *)
> (* now I try what the section says, *)
> Definition C' (A B: Type) := C A.
> Identity Coercion idC'C: C'>->C.
I guess the problem is that you define a coercion from C' to C;
and you would like to have one from C to C';
so that you can branch it to follow this diagram: C>->C'>->D.
But I guess, that such a coercion is not possible.
I don't know if you are interested in this:
Parameter f : forall A, C A -> forall B, D A B.
Coercion f: C>-> Funclass.
Variable X: C nat.
Check (X nat: D nat nat).
Check (X: forall B, D nat B).
> (* but none of this works *)
> Fail Coercion f: C'>->D.
> (* it is true that I can cast [f] to the desired type *)
> Check f : forall A B, C' A B -> D A B.
> (* and like this I can manually define a coercion from [C'] to [D]
> (even if I don't want to do it this way, because it introduces
> another identifier I'll have to unfold within proofs) *)
> Coercion f':= f : forall A B, C' A B -> D A B.
> (* but the coercions don't chain *)
> Parameters X Y : Type.
> Parameter c : C X.
> Check c : C' X Y.
> Fail Check c : D X Y.
> (* this works but I wouldn't call this "implicit" *)
> Check (c : C' X Y) : D X Y.
> Am I missing something or did I misunderstand the manual?
> Any ideas?
> Thanks in advance,
I never use coercions, so that I cannot tell for your last point.
- [Coq-Club] Identity Coercions and Uniform Inheritance Condition, Paolo Herms
- Re: [Coq-Club] Identity Coercions and Uniform Inheritance Condition, AUGER Cedric
- Message not available
