- To: Adam Chlipala <adam AT chlipala.net>
- Cc: Coq-Club <coq-club AT inria.fr>
- Subject: RE: [Coq-Club] Ltac infinite loop (or at least very slow
- Date: Thu, 28 Jul 2011 18:16:22 -0700
- Importance: Normal
I just realized the problem. My intent was to have an n*m algorithm where n and m are the number of leaves in the two trees. However the way I had the search setup before, the ComposeFirst... and ComposeSecond... rules could be arbitrarily interleaved causing an exponential explosion. I have attached the corrected code. It executes very quickly.
- Ken > Date: Thu, 28 Jul 2011 20:08:00 -0400 > From: adam AT chlipala.net > To: kendroe AT hotmail.com > CC: coq-club AT inria.fr > Subject: Re: [Coq-Club] Ltac infinite loop (or at least very slow > > Kenneth Roe wrote: > > Now on to the next issue--the call to the tactic solvePick2Vars at the > > very end of the example I've attached seems to go into an infinite > > loop (or at least is very slow). Can anyone tell me what is happening? > > Isn't your algorithm here exponential time, such that it shouldn't be > surprising that the algorithm runs for a long while for n = 12? > (Constant factors in Ltac aren't very good in the first place!) > > > Does auto implement backtracking? My impression was that it just > > keeps applying its rules until none are applicable. > > Yes, [auto] does backtracking; no, [auto] doesn't keep applying rules > until none are applicable. The depth argument to [auto] (which is > mandatory and defaults to 5) determines the depth of the search tree, so > there is always a cut-off point, even when further rules apply. > > I just checked the manual and was surprised to see that, indeed, it is > not at all clear there that [auto] backtracks! The hint is the text > "Prolog-like resolution procedure." |
test.v
Description: Binary data
- [Coq-Club] Ltac infinite loop (or at least very slow, Kenneth Roe
- Message not available
- Re: [Coq-Club] Ltac infinite loop (or at least very slow,
Adam Chlipala
- RE: [Coq-Club] Ltac infinite loop (or at least very slow, Kenneth Roe
