- To: coq-club AT inria.fr
- Subject: [Coq-Club] Coq Proof Help
- Date: Sat, 30 Jul 2011 19:32:17 +0000 (UTC)
Hi. Im having a problem with my Coq Proof and was hoping for some help and
guidance. I have part of my definition below:
Inductive Architecture : Set :=
| Create_Architecture (Arch_Name: string)(MyComponents: list Component)
(MyConnections: list Connector)
with
with
Connector : Set :=
| Create_Connector (Con_Name:string) (client: Component)(server:Component)
I wish to say that "A component term must be either a client or server of a
connection; but not both." I have come up with the following as a
representation
of the above in the coq (based on my definition above):
(forall con:Connector, forall c:Component, In con (MyConnections x) ->
(c = (client con) /\ c <> (server con)) \/ (c <> (client con) /\ c =
(server
con)))
However, Im not sure if that is correct (is it?), as when i get to the proof,
I
get stuck at the point
5 subgoals
con : Connector
c : Component
H0 : Connection1 = con
______________________________________(1/5)
c = HotelRes
The type of HoteRes is indeed Component (in this case, HotelRes is the client
of
the connection), however, since this is not in the set of assumptions, I cant
use something like the exact or auto tactics.
How could I proceed with such a proof? Thanks in advance.
- [Coq-Club] Coq Proof Help, zaman
- Re: [Coq-Club] Coq Proof Help, Adam Chlipala
