- To: Adam Chlipala <adam AT chlipala.net>
- Cc: AUGER Cedric <Cedric.Auger AT lri.fr>, coq-club AT inria.fr
- Subject: Re: [Coq-Club] Coq dies
- Date: Tue, 2 Aug 2011 14:21:28 +0200
Le Tue, 02 Aug 2011 08:43:21 -0400,
Adam Chlipala
a écrit :
> AUGER Cedric wrote:
> > I guess you meant coqide; you also should be more precise on the
> > problem you were trying to solve. Taking 1 or 2 minutes, is really a
> > bad omen.
> I disagree, though it depends on the sense of "bad omen." ;) It's
> easy for proof scripts that use a lot of automation to run for hours
> and use tens of gigabytes of RAM.
Precisely, the machine in which it was supposed to run is a 4Go one;
and as it was not precised 64 bits, I guess it is also a 32 bits one;
so using "tens of gigabytes of RAM" won't work.
Furthermore, I never consider proof scripts running for hours, since
that means for me that they are "one shot" proofs. I cannot wait hours
each time I want to modify a bit of the developpement.
- [Coq-Club] Coq dies, Marko Malikoviæ
- Re: [Coq-Club] Coq dies,
AUGER Cedric
Marko Malikoviæ
Laurent Théry
- Re: [Coq-Club] Coq dies, Frédéric Besson
Laurent Théry
Adam Chlipala
- Re: [Coq-Club] Coq dies, AUGER Cedric
Adam Chlipala
- Re: [Coq-Club] Coq dies, Marco Servetto
Adam Chlipala
Marko Malikoviæ
AUGER Cedric
