- To: Adam Chlipala <adam AT chlipala.net>
- Cc: Marco Servetto <marco.servetto AT gmail.com>, coq-club AT inria.fr
- Subject: Re: [Coq-Club] sig and sigT
- Date: Wed, 3 Aug 2011 14:19:43 +0200
Le Wed, 03 Aug 2011 07:56:10 -0400,
Adam Chlipala
a écrit :
> Marco Servetto wrote:
> > Hi, I'm tring to understand sig, sigT, their differences and how to
> > use they.
> > For example, i tried to define elements
> > Definition ex1:= (( [ ], (NoDup_nil nat)) :{x:list nat | NoDup x}).
> > Definition ex2:= (( [ ], (NoDup_nil nat)) :{x:list nat& NoDup x}).
> > but with no success.
> > How to define elements of type {x:list nat | NoDup x} or {x:list
> > nat& NoDup x} ? and what is the difference between this two types?
> You've already done the hard work of figuring out which type family
> is matched with each of the different notations. If you need to do
> that in the future, you might like to use the [Locate] command,
> illustrated like: Locate "{ _ : _ | _ }".
> This command finds [sig]. Then you can run:
> Print sig.
> ...which will show you the type definition, including the single
> constructor and its type. As far as I know, the standard library
> contains no shorthand syntax for applying this constructor, so you
> just call it directly (or define your own notation, as I often do).
On this page you can find an example for such a notation:
http://coq.inria.fr/cocorico/AUGER_ExtractionTuto
I copy paste the interesting part (and remove some comments, you may
not be interested in)
Record spec (T: Type) (Spe: T → Prop): Type :=
Cast { spec_val: T;
π: Spe spec_val
(** This definition is isomorphic to the one of sig,
so you may replace Cast by exist, and spec with sig;
I defined a Record not to have to define projections,
but you can of course do:
Definition spec_val {A: Type} {P: A -> Prop} (s: sigT P) :=
let (x,_) := s in x.
and
Definition π {A: Type} {P: A -> Prop} (s: sigT P) :=
let (_,x) := s in x.
to have them
Notation "{ x : T 'st' Π }" :=
(spec (fun (x: T) => Π))
(x at level 99, format "'[' { x : T '/' 'st' Π } ']'").
Notation "{ x 'st' Π }" := {x:_ st Π}
(x at level 99, format "'[' { x '/' 'st' Π } ']'").
Notation "{ x '&' Π }" :=
(spec (fun (_: x) => Π))
(x at level 99, format "'[' { x '/' '&' Π } ']'").
Notation "{: x :}" := {|spec_val:=x|}.
(** This syntax will mark places where a proof is expected
inside of refine terms (since the [π] term is not provided).
So in practice, we will find [{: x (*label to a proof*) :}].
Thus we can refer us to it inside of our term definitions. *)
Definition dummy: {unit & True}.
refine ( {: tt (*tt is such that err... True *) :} ).
Proof.
trivial.
Defined.
So that in your case, you can do:
Notation "{: x :}" := (exist _ x _).
Notation "{: x, y :}" := (existT _ x y).
Definition ex1: {x: list nat | NoDup x}.
refine (
{· [ ] (* [] has no duplication *) ·}
Proof. (* [] has no duplication *)
apply NoDup_nil.
Defined.
Definition ex1': {x: list nat | NoDup x} := exist _ _ (NoDup_nil nat).
Definition ex2: {x:list nat & NoDup x} := {: [ ], NoDup_nil nat :}.
Definition ex2': {x:list nat & NoDup x}
:= existT _ [ ] (NoDup_nil nat).
I didn't test it, so it may contain some error(s), but the wiki page
has been tested on coq 8.3
> If this advice is insufficient, please feel free to write again!
> (The same advice should also make it possible to see the difference
> between [sig] and [sigT].)
- [Coq-Club] sig and sigT, Marco Servetto
- Re: [Coq-Club] sig and sigT,
Adam Chlipala
Marco Servetto
- Re: [Coq-Club] sig and sigT, AUGER Cedric
- Re: [Coq-Club] sig and sigT, Adam Chlipala
Marco Servetto
Adam Chlipala
