coq-club - Re: [Coq-Club] How to project/define these attributes?
chronological Thread
  • To: zaman.a25 AT gmail.com
  • Cc: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] How to project/define these attributes?
  • Date: Mon, 08 Aug 2011 11:25:16 -0400
 wrote:
I have the Inductive definition:
Protocol : Set :=
| Create_ProtocolB (pEvent: ProtocolEvent)
| Create_ProtocolR (pR:Protocol)(RepOp1: RepetitionOperator)
| Create_ProtocolEE (protocol1: Protocol)(BinOp2: BinaryOperator)(protocol2:
Protocol)
And wish to define the attribute projections, but Coq gives an error. How
would
I define such attributes to get the ProtocolEvent (pEvent) of each Protocol?
Ive tried (for the attribute pEvent):
Definition pEvent : Protocol -> ProtocolEvent :=
(fun x: Protocol =>
match x with
| (Create_ProtocolB pe) => pe
| (Create_ProtocolR p r) => p
| (Create_ProtocolEE p1 bop p2) => p1
end).
From your prose description, it isn't clear to me what you mean to do. The above code doesn't make sense to me as "a way of getting the ProtocolEvent of a Protocol," since the second two pattern matching cases clearly aren't returning [ProtocolEvent]s.
Perhaps the answer to your question is that you are thinking too Lisply and should be prepared to use explicit pattern matching throughout your code, rather than writing "attribute projection" functions once? I believe that would be the most idiomatic style, but you could also implement "projections" that return [option] types, yielding [None] when the projection doesn't make sense for its actual argument. Yielding a safe default value in inapplicable cases would be a further option, which would bother most Coq users even more, on stylistic grounds. ;)
P.S.: None of the parentheses in your [pEvent] definition are needed.
