- To: ê¹€í˜•ì„ <hskiowa AT kaist.ac.kr>
- Cc: coq-club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] On Notations
- Date: Mon, 29 Aug 2011 16:55:49 +0200
Take a look at the coq reference manual;
here is an exerpt which may be of some help:
12.1.3 Complex notations
Notations can be made from arbitraly complex symbols. One can for
instance define prefix notations. Coq < Notation "~ x" := (not x) (at
level 75, right associativity).
One can also define notations for incomplete terms, with the hole
expected to be inferred at typing time. Coq < Notation "x = y" := (@eq
_ x y) (at level 70, no associativity).
One can define closed notations whose both sides are symbols. In this
case, the default precedence level for inner subexpression is 200. Coq
< Notation "( x , y )" := (@pair _ _ x y) (at level 0).
One can also define notations for binders.
Coq < Notation "{ x : A | P }" := (sig A (fun x => P)) (at level 0).
In the last case though, there is a conflict with the notation for type
casts. This last notation, as shown by the command Print Grammar constr
is at level 100. To avoid x : A being parsed as a type cast, it is
necessary to put x at a level below 100, typically 99. Hence, a correct
definition is Coq < Notation "{ x : A | P }" := (sig A (fun x => P))
(at level 0, x at level 99).
See the next section for more about factorization.
- [Coq-Club] On Notations, ±èÇü¼±
- Re: [Coq-Club] On Notations, AUGER Cedric
