- To: AUGER Cedric <Cedric.Auger AT lri.fr>
- Cc: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Generating fresh names with string variables
- Date: Thu, 8 Sep 2011 17:11:43 +0200
> AFAIK, you cannot convert a string of the String coq library to a
> string used by tactics, but you can provide a (tactic) string to the
> tactic, so that it is used to generate identifiers.
> Ltac demo s :=
> let H := fresh s in
> intros H.
> Goal forall (t u v:bool), True.
> intro.
> demo u.
> demo t.
> split.
> Qed.
Yes, I knew this was possible. What I would want, however, is to be able to
write 'demo "u"' instead, seeing as both 'fresh u' and 'fresh "u"' work.
From the replies I have gotten it seems that I'd have to go into the ML-level
to achieve this though.
Thank you for your time. It's all a bit clearer now :)
/Jesper
- [Coq-Club] Generating fresh names with string variables, Jesper Bengtson
- Re: [Coq-Club] Generating fresh names with string variables,
AUGER Cedric
- Re: [Coq-Club] Generating fresh names with string variables, Jesper Bengtson
AUGER Cedric
