coq-club - Re: [Coq-Club]ground terms in First-Order Logic
chronological Thread
  • From: Pierre Boutillier <pierre.boutillier AT pps.jussieu.fr>
  • To: Coq-Club <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club]ground terms in First-Order Logic
  • Date: Mon, 19 Sep 2011 09:04:07 +0200
Hi,
Le 19 sept. 11 à 08:39, Levis John a écrit :
Now i want to define GroundTerms, a subset of Term, in which terms have no free variables:
Inductive GroundTerm:Term->Prop:=
|FuncApp_GroundTerm:forall (func:Function L)(ts : Terms (arityFunction L func)),
GroundTerms (arityFunction L func) ts -> GroundTerm (FunApp func ts)
|Tnil_GroundTerms:GroundTerms 0 Tnil
|Tcons_GroundTerms:forall(n:nat)(t:Term)(ts:Terms n),
  GroundTerm t ->GroundTerms n ts-> GroundTerms (S n) (Tcons n t ts).
The GoundTerm definition makes sense to me, but the Coq complains that Parameters should be
syntactically the same for GroundTerm and GroundTerms.
Any suggestions?
Coq complains because n is a parameter of GroundTerms and not of GroundTerm but look : n isn't a parameter at all
 - Tnil_GroundTerms returns GroundTerms 0 ... and not GroundTerms n ...
- Tcons_GroundTerms GroundTerms (S n) ... instead of GroundTerms n ... .
So just define n as an argument thanks to
+ with GroundTerms : forall (n:nat), (Terms n)->Prop:=
and you'll be fine
if you don't understand why the : place changes everything you can
 - try to fight http://coq.inria.fr/refman/Reference-Manual006.html#toc31
 - read http://adam.chlipala.net/cpdt/html/InductiveTypes.html
All the best,
Pierre Boutillier
