coq-club - Re: [Coq-Club] Matthieu Sozeau's Equations
chronological Thread
  • From: Matthieu Sozeau <matthieu.sozeau AT gmail.com>
  • To: Randy Pollack <rpollack0 AT gmail.com>
  • Cc: Coq-Club Club <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] Matthieu Sozeau's Equations
  • Date: Wed, 28 Sep 2011 14:51:44 +0200
Hi Randy,
  You still need to install the plugin, it's not part of Coq proper. Code is
available on github that works with the current trunk version (the coq-trunk
branch). The README there should be sufficient to get you started. Otherwise
it's a bug. And there will be an official release with 8.4.
Hope this helps,
-- Matthieu
Le 27 sept. 2011 à 10:05, Randy Pollack
 a écrit :
> My first attempt to use Equations.  The Tutorial
> (mattam.org/research/coq/equations-intro.html) says : "... requiring
> no prior knowledge of the tool. We start our Coq primer session by
> importing the Equations module.
>  Require Import Equations.
> Coq (8.3pl2) says "Error: Cannot find library Equations in loadpath".
> Any help is appreciated.
> Randy
