- To: Cody Roux <cody.roux AT inria.fr>
- Cc: Coq-Club Club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] a question about CIC/Coq consistency
- Date: Wed, 28 Sep 2011 11:15:21 -0400 (EDT)
On Wed, 28 Sep 2011, Cody Roux wrote:
----- Mail original -----
De: "Andrej Bauer"
<andrej.bauer AT andrej.com>
À: "Benjamin Werner"
<benjamin.werner AT polytechnique.org>
Cc: "Coq-Club Club"
Envoyé: Mercredi 28 Septembre 2011 15:05:14
Objet: Re: [Coq-Club] a question about CIC/Coq consistency
Coq is an extension of PA.
What does "extension" mean here?
With kind regards,
Andrej
I'm sure someone else will have answered by the time this is sent but I'll
try to give a quick idea about measuring the relative strengths of logical
theories: In this case we can take a statement about Peano Arithmetic, for
example:
forall x y, exists z, x * z = y
And translate that into a Coq statement:
forall (x y : nat), exists z:nat, x * z = y
where the multiplication and equality are translated to the ones in the
standard library. Now you can translate every statement of Peano Arithmetic
into one of Coq, and ask yourself which statements provable in PA are
provable in Coq.
It is in fact easy to show that all statements provable in PA -without the use of the
excluded middle- have translations which are in fact provable in the Coq logic. The fragment
of PA that does not admit the excluded middle is commonly called HA, Heyting Arithmetic. So
there are some statements that are provable in PA and not in Coq (or HA). However it can be
shown that if PA is contradictory, i.e. PA proves 0 =\= 1, then so does HA, and therefore Coq
proves the translation of that statement "O <> S O" (which implies False).
As a side note, it is interesting to ask whether there are statements from HA
such that their translations are provable in Coq, but that are themselves not
provable in HA. The answer is yes! There are many such statements, one of the
famous ones being the Goodstein Theorem, another being the Godel encoding of
the consistency of Arithmetic.
In conclusion, Coq can prove all theorems of Peano Arithmetic that do not use
excluded middle in their proofs, and has a strictly stronger consistency
strength: consistency of Coq implies that of PA, but not vice-versa.
I'm not sure that the consistency strength of CIC or Coq are precisely known
with respect to set theories but I believe that CIC with universes and
predicative set is weaker than, but of similar strength to, ZF set theory (in
particular it is stronger than ZF - axiom of replacement). Benjamin probably
knows more about this than I do.
I hope I am not rehashing things you know very well,
All the best,
I think you mean to say that Coq can interpret PA rather than Coq extends PA.
BTW, you can intepret *all* proofs in PA into Coq, even the ones using excluded midde, with a suitable double negation intepretation. This is how I prove the consistency of PA in my work.
Russell O'Connor <http://r6.ca/>
``All talk about `theft,''' the general counsel of the American Graphophone
Company wrote, ``is the merest claptrap, for there exists no property in
ideas musical, literary or artistic, except as defined by statute.''
- [Coq-Club] a question about CIC/Coq consistency, Vincent Siles
- Re: [Coq-Club] a question about CIC/Coq consistency, roconnor
- Re: [Coq-Club] a question about CIC/Coq consistency, Vladimir Voevodsky
- Re: [Coq-Club] a question about CIC/Coq consistency, Cody Roux
- <Possible follow-ups>
Benjamin Werner
Andrej Bauer
Cody Roux
Cody Roux
Andrej Bauer
