- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] What are type classes?
- Date: Tue, 1 Nov 2011 23:16:42 +0100
On Nov 1, 2011, at 10:38 PM, Victor Porton wrote:
> What is the difference between type classes and dependent records?
I'm am by no means an expert, but I'm pretty sure they will join this
discussion soon enough to correct my mistakes :)
Anyway,
The are essentially the same thing, except that they are used for something
entirely different.
Type classes allow you to specify an abstract "interface" for which you want
the system to *automatically* find an implementation. Hence the main
difference: type class instances (terms of a record type) are registered in a
special "auto" database. This database is then used to resolve the class
requirements you specify in for example a lemma.
In fact IIRC you can add values for a record to that database yourself and
essentially get the same thing.
It is explained much better here
http://mattam.org/research/publications/First-Class_Type_Classes-TPHOLs-200808.pdf
The basic example there is this,
(* define some class of numbers with a zero and one element and a plus
operation. *)
Class num α :=
{ zero : α
; one : α
; plus : α → α → α
(* we now define two different instances of num *)
Instance nat_num : num nat :=
{ zero := 0 % nat
; one := 1 % nat
; plus := Peano.plus
Require Import ZArith.
Instance Z_num : num Z :=
{ zero := 0 % Z
; one := 1 % Z
; plus := Zplus
(* introduce some notations *)
Notation "0" := zero.
Notation "1" := one.
Infix "+" := plus.
(* here the system automatically finds the correct instance *)
Check (λ x : nat, x + (1 + 0 + x)).
Check (λ y : Z, y + (1 + 0 + y)).
So the statement "x + (1 + 0 + x)" is implicitly parametrized by an instance
of num, which is then automatically resolved.
Another way we use this often, is like the following (I just picked something
random)
https://github.com/0x01/math-classes/blob/master/src/theory/groups.v#L70
Section groupmor_props.
Context `{Group A} `{Group B} {f : A → B} `{!Monoid_Morphism f}.
(* ^^ here we implicitly parametrize the next lemma with two groups, and
some more stuff...
Because these are classes, coq will automatically try to resolve the
instances.
Of course you can use @preserves_negate to specify the instances
yourself or
use (A := ..) to specify an otherwise implicit parameter
Lemma preserves_negate x : f (-x) = -f x.
Proof.
apply (left_cancellation (&) (f x)).
rewrite <-preserves_sg_op.
rewrite 2!right_inverse.
apply preserves_mon_unit.
Qed.
End groupmor_props.
This is more or less how I understand it, but I'm happy to see better
examples, etc.
HTH,
Jelle.
- [Coq-Club] What are type classes?, Victor Porton
- Re: [Coq-Club] What are type classes?, Matthieu Sozeau
- Re: [Coq-Club] What are type classes?, Jelle Herold
