- From: David Pichardie <david.pichardie AT inria.fr>
- To: Victor Porton <porton AT narod.ru>
- Cc: coq-club AT inria.fr
- Subject: Re: [Coq-Club] What are type classes?
- Date: Wed, 2 Nov 2011 09:18:08 -0400
Here is how I would explain the difference between a type class and a record.
Best regards,
David.
(* let's define a type class for computable equality tests *)
Class EqDec (A:Type) := {
eq_dec: forall (x y:A), {x=y}+{x<>y}
Instance EqDec_nat : EqDec nat.
constructor; decide equality.
Qed.
(* if we print EqDec, it's look like a record *)
Print EqDec.
(* but if we define the same as record, there will be a big difference when
we use the
field [eq_dec] (see below) *)
Record EqDec' (A : Type) : Type := Build_EqDec'
{ eq_dec' : forall x y : A, {x = y} + {x <> y} }.
Definition EqDec'_nat : EqDec' nat.
Qed.
(* eq_dec and eq_dec' have the same type *)
Check @eq_dec.
Check @eq_dec'.
(* but Coq uses a more powerfull mechanism to infer the second argument of
eq_dec *)
Definition eq_nat_dec : forall (x y:nat), {x=y}+{x<>y} := @eq_dec nat _. (*
Coq is happy *)
Definition eq_nat_dec : forall (x y:nat), {x=y}+{x<>y} := @eq_dec' nat _. (*
here Coq complains because it can fill the hole itself *)
(* Hope this help *)
Le 1 nov. 2011 à 19:32, Victor Porton a écrit :
> 02.11.2011, 02:16, "Jelle Herold"
>Â <jelle AT defekt.nl>:
>> On Nov 1, 2011, at 10:38 PM, Victor Porton wrote:
>>> What is the difference between type classes and dependent records?
>> I'm am by no means an expert, but I'm pretty sure they will join this
>> discussion soon enough to correct my mistakes :)
> http://coq.inria.fr/cocorico/TypeClasses :
> When you define a type class using Class, all of its members will be
> declared such that the argument for the instance is implicit. If you would
> prefer that this were not the case, simply use Structure instead. They are
> identical except for this one difference.
> And in Coq reference it is said:
> Structure is a synonym of the keyword Record.
> Thus the only difference is presence of implicit arguments. Right? What
> experts can say?
> Victor Porton - http://portonvictor.org
- [Coq-Club] Re: What are type classes?, Victor Porton
- Re: [Coq-Club] What are type classes?, David Pichardie
- Re: [Coq-Club] Re: What are type classes?, AUGER Cedric
