- From: Thomas Braibant <thomas.braibant AT gmail.com>
- To: Victor Porton <porton AT narod.ru>
- Cc: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Why backtick notation is needed?
- Date: Fri, 4 Nov 2011 18:57:16 +0100
The back-tick is related to type-classes, not to implicit arguments.
In your example, you do not deal with implicit arguments. Check the
following exceprt: there, id2 has an implicit argument, while id1 does
not have one (which requires to give this argument by hand, while it
can be inferred from the context).
Definition id (A : Type) (x : A) := A.šDefinition id2 {A : Type} (x : A) := A.
Check id2 1.šCheck id 1.š(* fails *)
Check id nat 1. (* succeeds *)
thomas
On Fri, Nov 4, 2011 at 6:48 PM, Victor Porton
wrote:
> I installed Coq 8.3.
> The following:
> Definition id `(x : nat) : nat := x.
> Print id.
> Definition id2 (x : nat) : nat := x.
> Print id2.
> Definition v := id O.
> Definition v2 := id2 O.
> Print v.
> Print v2.
> Produces the output:
> id = fun x : nat => x
> š š : nat -> nat
> Argument scope is [nat_scope]
> id2 = fun x : nat => x
> š š : nat -> nat
> v = id 0
> š š : nat
> v2 = id2 0
> š š : nat
> You see that types of id and id2 are identical.
> Moreover not only id but also id2 works with an implicit argument.
> What is the point to use backtick, if it work implicitly even without it?
> Victor Porton - http://portonvictor.org
- [Coq-Club] Why backtick notation is needed?, Victor Porton
- Re: [Coq-Club] Why backtick notation is needed?, Thomas Braibant
Victor Porton
- Re: [Coq-Club] Why backtick notation is needed?, Alexandre Pilkiewicz
Victor Porton
Victor Porton
Victor Porton
