coq-club - [Coq-Club] How to write a lemma?
chronological Thread
  • To: Coq <coq-club AT inria.fr>
  • Subject: [Coq-Club] How to write a lemma?
  • Date: Mon, 07 Nov 2011 03:11:26 +0400
  • Envelope-from: porton AT yandex.ru
Require Import sset2.
Class Base {set: Set} := {
Class Relation {set: Set} := {
  relation_is_base :> @Base set;
  mygraph: Set; (*mygraph: set->set->Prop*)
  is_rel: is_graph mygraph;
  is_inside: sub mygraph (product set set)
Definition is_inside2 `{Relation} := sub (domain mygraph) set & sub (range
mygraph) set.
Lemma TwoInside: is_inside <-> is_inside2.
(*Intended to be proved with corr_propcc*)
The lemma TwoInside does not compile. I understand the reason it does not
compile. But what is the correct way to rewrite it so that it will work as it
is intended? That is I want to state that is_inside and is_inside2 are
equivalent, provided they are quantified in the right way.
Victor Porton - http://portonvictor.org
