coq-club - Re: [Coq-Club] How to define combination in coq
chronological Thread
  • To: ��ӣ <phoebezz AT 163.com>
  • Cc: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] How to define combination in coq
  • Date: Mon, 07 Nov 2011 07:38:41 -0500
×óÓ£ wrote:
I'm trying to define a function to compute the combination of sets, which pick an element from every set and combine into another set. Let ci be the number of element in set i .The total number of elements in result set will be
Since you're talking about numbers, I presume you only mean to deal with _finite_ sets? If so, you have some representation choices to make. Certainly the function is easy to implement over lists, though you might want to ensure lack of duplicates in lists, for a fully faithful representation. The "list combination" function is a standard exercise in functional programming, bringing in very little that is new to Coq compared to OCaml.
