coq-club - Re: [Coq-Club] newbie: dependent types
chronological Thread
  • From: "gallais @ ensl.org" <guillaume.allais AT ens-lyon.org>
  • To: Ramana Kumar <ramana.kumar AT gmail.com>
  • Cc: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] newbie: dependent types
  • Date: Tue, 8 Nov 2011 18:37:07 +0000
Hi Ramana,
The usual way to do this kind of thing is to have term parametrized
by a typing context. Here is an example.
Inductive type : Set :=
  | base : type
  | arrow : type -> type -> type.
Definition Env := list type.
Inductive in_Env : type -> Env -> Set :=
  | here : forall s G, in_Env s (cons s G)
  | there : forall s t G, in_Env s G -> in_Env s (cons t G).
Inductive term (G : Env) : type -> Set :=
  | var : forall (s : type), in_Env s G -> term G s
  | lam : forall (s t : type), term (cons s G) t -> term G (arrow s t)
  | app : forall (s t : type), term G (arrow s t) -> term G s -> term G t.
Cheers,
guillaume
On 8 November 2011 17:36, Ramana Kumar
 wrote:
> Dear Coq Club
> I am writing my first (semi-)serious Coq file, and I'd like to get
> help from anyone willing to improve my style and tell me about things
> in the libraries I don't know about yet (and fix my errors...).
> I am trying to define the terms (and types) of simple type theory (aka
> higher-order logic) as an inductive datatype in Coq using dependent
> types to ensure that all terms are well-typed from the start. Is that
> possible?
> At the bottom of my file (attached) is the attempt to do it from the
> start. Above it, I also tried a more convoluted way where I first
> define preterms (which may not be well-typed) then try to take a
> subset of them. But I am running into problems with testing equality
> (among other things).
> A specific side-question: Is there a better way to get dependently
> typed lists than the way I have defined ilist?
> Any other comments on style are welcome.
> I look forward to any replies :)
> Thanks
> Ramana
