- To: Adam Chlipala <adamc AT csail.mit.edu>
- Cc: Victor Porton <porton AT narod.ru>, Coq <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Structured proofs do not work inside sections
- Date: Fri, 11 Nov 2011 21:22:58 -0200
I'm just starting with Coq, and I'm intrigued by how little structured
proofs seem to be used here, as you say. Declarative proofs, in
principle, should be much easier to read and maintain (not necessarily
to write). And in other systems, like Isabelle, they seem to have a
wider adoption (they had it for a longer time too).
I'm curious about the reasons you wouldn't recommend using it. Is it
just the state of the current implementation in Coq the problem?
Thanks,
Alan
On Fri, Nov 11, 2011 at 8:28 PM, Adam Chlipala
wrote:
> A brief note, and someone should correct me if I'm wrong about this: I
> believe the user base of "structured proofs" in Coq is negligible. Few of
> us here have any experience with it or recommend using it.
- [Coq-Club] Structured proofs do not work inside sections, Victor Porton
- Re: [Coq-Club] Structured proofs do not work inside sections,
Adam Chlipala
- Re: [Coq-Club] Structured proofs do not work inside sections, Alan Pogrebinschi
Adam Chlipala
Pierre Courtieu
Alexandre Pilkiewicz
- Re: [Coq-Club] Structured proofs do not work inside sections, Adam Chlipala
Pierre Courtieu
Adam Chlipala
- Re: [Coq-Club] Structured proofs do not work inside sections, Benedikt Ahrens
Adam Chlipala
