coq-club - Re: [Coq-Club] A simple script does not work
chronological Thread
  • To: Pierre Courtieu <pierre.courtieu AT cnam.fr>, Coq <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] A simple script does not work
  • Date: Mon, 14 Nov 2011 21:45:14 +0400
  • Envelope-from: porton AT yandex.ru
14.11.2011, 21:42, "Pierre Courtieu"
<Pierre.Courtieu AT cnam.fr>:
> 2011/11/14 Victor Porton
> <porton AT narod.ru>:
>> šI am now learning how to create an object of a derived class having an
>> object of a base class.
>> šAs the first act I decided to play with plain dependent records (not yet
>> with type classes).
>> šBut that simple script does not work in some mysterious (for me) reason.
>> Please explain why it does not verify.
>> š[[[[
>> šRecord A := {
>> ššnum: nat
>> š}.
>> šRecord B := {
>> ššbase : A;
>> šše: num base > 2
>> š}.
>> šDefinition A_Sample: A := {| num := 3 |}.
>> šDefinition B_Sample: B := {| base := A_Sample |}.
> B_sample has only one field whereas the type B expects two fields. So
> your record is not complete. You should have:
I've read somewhere that if not all fields of a dependent record are given it
enters into proof mode where the user may fill missing fields.
Why this does not happen now?
> Lemma e_for_3: num A_Sample > 2.
> Proof.
> ššauto.
> Qed.
> Program Definition B_Sample: B := {| base := A_Sample; e:= e_for_3 |}.
> P.C.
>> šProof. Admitted.
>> š]]]]
>> š--
>> šVictor Porton - http://portonvictor.org
