coq-club - Re: [Coq-Club] Specifying fields of a base class?
chronological Thread
  • From: Vincent Siles <vincent.siles AT ens-lyon.org>
  • To: Victor Porton <porton AT narod.ru>
  • Cc: Coq <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] Specifying fields of a base class?
  • Date: Tue, 15 Nov 2011 08:13:56 +0100
I already explained to you that these classes are not the same the
classes you can find in object oriented programming like Java or C++.
Please learn the difference and stop asking to change Coq to be
like you want because you can't read the manual.
2011/11/14 Victor Porton
<porton AT narod.ru>:
> Oh, I found a solution myself:
> Instance sample: Derived := {
>  link:={|n:=0|}
> trivial.
> But I think, it would be better (for a future version of Coq) if my naive
> solution (see below) also worked.
> 15.11.2011, 00:33, "Victor Porton"
>> This does not compile. First: is it a feature or a misfeature? Second: How
>> to write what I intended in Coq 8.3pl2?
>> Class Base := {
>>   n: nat
>> Class Derived := {
>>   link :> Base
>>   n := 0
>> Victor Porton - http://portonvictor.org
