coq-club - Re: [Coq-Club] One more deficiency of Coq?
chronological Thread
  • To: Victor Porton <porton AT narod.ru>
  • Cc: Coq Club <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] One more deficiency of Coq?
  • Date: Tue, 15 Nov 2011 16:38:20 +0100
Le 15 nov. 2011 à 16:29, Victor Porton a écrit :
> 15.11.2011, 14:08, "Matthieu Sozeau"
> <matthieu.sozeau AT gmail.com>:
>> Le 15 nov. 2011 à 00:07, Victor Porton a écrit :
>>>  The following does not verify, because in some reason Coq does not do a
>>> coercion from Derived to Base.
>>>  Maybe it is an intended behavior but for me it seems like a conceptual
>>> error in Coq type classes.
>> Well, maybe you should read about typeclasses in Haskell and Coq to
>> understand why they're
>> implemented like this. In case you think "base" is declared a coercion,
>> the manual will
>> inform you that it is not the case, "base" is simply declared as an
>> instance, of type
>> [Derived -> Base]. You can declare it as a coercion yourself if you like.
> Thus I probably misunderstand the Reference Manual.
> From the page 363 of Reference Manual 8.3.pl2:
> Coq < Class PreOrder (A : Type) (R : relation A) :=
> Coq < { PreOrder_Reflexive :> Reflexive A R ;
> Coq < PreOrder_Transitive :> Transitive A R }.
> The syntax :> indicates that each PreOrder can be seen as a Reflexive
> relation. So each
> time a reflexive relation is needed, a preorder can be used instead. This
> is very similar to the coercion
> mechanism of Structure declarations. The implementation simply declares
> each projection as an
> instance.
> Why this does not work as I expect, that is automatically creating coercion
> from Derived to Base?
Did you read what you just quoted there? " The implementation simply declares
instance." "This is very similar to the coercion mechanism of Structure
declarations." meaning it is not
_the same_, but _similar_. If you write
[@n
 derived] you are bypassing the instance resolution, if you
wrote
[@n
 _], it would infer the chain of "coercions" [base derived]: e.g:
Definition test (derived: Derived) := @n _.
Set Printing All.
Print test.
>> test = fun derived : Derived => @n (@base derived)
     : Derived -> nat
 One is not supposed to use @n 1
-- Matthieu
