coq-club - Re: [Coq-Club] Comparing records (and dependent records)
chronological Thread
  • To: Victor Porton <porton AT narod.ru>
  • Cc: Coq Club <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] Comparing records (and dependent records)
  • Date: Fri, 18 Nov 2011 14:51:20 -0500
Which book or other source are you reading to learn Coq? Especially the first of these questions is pretty basic.
Victor Porton wrote:
Record T := {
  x y : num
Variable A B : T.
Now suppose we know [x A = x B] and [y A = y B]. Which ways we may infer [A =
B] from that?
Do (degenerate) "case analysis" on the constructor used to build each record, as [Record] is shorthand for [Inductive].
Also what about dependent records? Are they equal even in the case if they
have different justifications (proved by different lemmas)? Can we infer
equality of two dependent records comparing only data fields (not the
conditions)?
The idea of a dependent record type has no fundamental concept of "conditions," so the question seems ill-formed. You probably want to read about proof irrelevance.
