coq-club - Re: [Coq-Club] Making a definition really opaque
chronological Thread
  • To: coq-club AT inria.fr
  • Cc: alexandre.pilkiewicz AT polytechnique.org
  • Subject: Re: [Coq-Club] Making a definition really opaque
  • Date: Sun, 20 Nov 2011 12:52:39 +0100
Dear Alexandre,
> There seems to be a difference of opacity between a definition that is
> made opaque, and a Qed at the end of a lemma:
Indeed.
> Is there a good reason for that?
My understanding is that it is not so simple to allow the existence of such a
command, labelling  some reductions that used to be allowed but should be
blocked from now on.
Actually you might meanwhile have defined some other (well-typed) terms whose
type-checking depend on the reduction you now decide to block.
Suppose you define a function:
  Definition f (x : nat) := x.
and prove
  Lemma foo : f 0 = 0.
or even define a dependent term whose type depends on (f 0) being convertible
with 0.
I do not know what should be the status of such terms "after" a
"RealOpaque f" declaration. Do they become ill-typed?
 And if not, what would be a
> "RealOpaque" command, to avoid ma opaque constant to be "basically
> transparent"?
I have however learned from Georges Gonthier some tricks that may help you to
achieve what you ask for.
The first solution is to tag terms with explicitly blocked cases:
First define an opaque tt:
  Lemma master_key : unit. Proof. exact tt. Qed.
Now this function turns a term of type A into a "locked" one:
  Definition locked A := let 'tt := master_key in fun x : A => x.
From now on, (locked t) and t are provably equal but not convertible, since
the
iota-reduction is blocked by the opaque status of master_key:
  Lemma lock A x : x = locked x :> A.
  Proof. now unfold locked; case master_key. Qed.
An other option is to use the module system to "opacify" your definition.
Suppose I want an opaque version of the identity function on nat:
I start by defining a signature for my opaque identity, which specifies the
type
of the constant and what this constant should be provably equal to:
  Module Type fDefSig.
  Parameter f : nat -> nat.
  Axiom fEdef : f = (fun n : nat => n).
  End fDefSig.
Then I provide an implementation of this interface:
  Module fDef : fDefSig.
  Definition f : nat -> nat := (fun n : nat => n).
  Definition fEdef := refl_equal f.
  End fDef.
And finally I export the module:
  Export fDef.
Hope this helps.
Best,
assia
