- To: Alexandre Pilkiewicz <alexandre.pilkiewicz AT polytechnique.org>
- Cc: Coq Club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] typeclasses and sections
- Date: Mon, 21 Nov 2011 14:27:56 -0800
Thank you! Where can I find documentation about "Context"? It is not
in the index of the Coq reference manual. Nor is your "Generalizable
Variable" -- what does that do?
On Mon, Nov 21, 2011 at 13:32, Alexandre Pilkiewicz
wrote:
> Context allows you to do this:
> Class inhabited (A:Type):= {repr:A}.
> Generalizable Variable A.
> Section FOO.
> Context `{inhabited A}.
> Definition unsafe_head (l:list A) :=
> match l with
> | nil => repr
> | cons x _ => x
> end.
> End FOO.
> About unsafe_head.
> unsafe_head : forall A : Type, inhabited A -> list A -> A
> Arguments A, H are implicit and maximally inserted
> Argument scopes are [type_scope _ list_scope]
> unsafe_head is transparent
> Expands to: Constant Top.unsafe_head
> On Mon, Nov 21, 2011 at 9:38 PM, Michael Shulman
> <mshulman AT ucsd.edu>
> wrote:
>> Is it possible to declare a hypothesis in a section which will be
>> automatically *implicitly* generalized upon completion of the section?
>> In particular, I would like to do this for an instance declaration, so
>> that
>> Section sect.
>> Hypothesis A : Type.
>> Hypothesis inst : type_class A.
>> Theorem thm : B -> C.
>> End sect.
>> would be equivalent to
>> Theorem `{inst : type_class A} : B -> C.
>> I suppose that I can do this with
>> Implicit Arguments thm [[A] [inst]].
>> (Is that literally the same thing, or is it going to miss out on some
>> typeclass magic?) In any case, that is tedious if the section
>> contains many definitions and theorems.
>> Mike
- [Coq-Club] typeclasses and sections, Michael Shulman
- Re: [Coq-Club] typeclasses and sections, Robbert Krebbers
- Re: [Coq-Club] typeclasses and sections, Michael Shulman
Tom Prince
Michael Shulman
- Re: [Coq-Club] typeclasses and sections, Tom Prince
Michael Shulman
Tom Prince
