- To: Daniel Schepler <dschepler AT gmail.com>
- Cc: coq-club AT inria.fr, Pierre Casteran <pierre.casteran AT labri.fr>, Victor Porton <porton AT narod.ru>
- Subject: Re: [Coq-Club] Dependent records conditions
- Date: Tue, 22 Nov 2011 16:35:10 +0100
Le Mon, 21 Nov 2011 08:33:08 -0800,
Daniel Schepler
a écrit :
> On Monday, November 21, 2011 07:00:51 AM Pierre Casteran wrote:
> > Le 21/11/2011 15:53, Victor Porton a écrit :
> > > Parameter A : Set.
> > > Parameter B : A -> Prop.
> > > Structure Foo := mkFoo { a : A; b : B a }.
> > > (* How to prove this lemma? Is it possible at all? *)
> > > Lemma my (u : Foo) : B (@a u).
> > Is it possible and *******trivial*********
> > destruct u;trivial.
> > Qed.
> Also, Coq defines this lemma for you automatically:
> Check b.
> b
> : forall f : Foo, B (a f)
By the way, I wanted to give the same reply as Daniel, but with this
syntax:
Proof (b u).
But it didn't work:
> Error: Command 'Proof ...' can only be used at the beginning of the proof.
I guess it is because "my" has parameter, so an implicit "intros u."
may have been automatically inserted; but the error message is quite
misleading (IMO), as we are at the beginning of the proof!
- [Coq-Club] Dependent records conditions, Victor Porton
- Re: [Coq-Club] Dependent records conditions,
Pierre Casteran
Daniel Schepler
- Re: [Coq-Club] Dependent records conditions, AUGER Cedric
Daniel Schepler
Pierre Casteran
