coq-club - Re: [Coq-Club] Take a proof of a true proposition
chronological Thread
  • To: David Pichardie <david.pichardie AT inria.fr>
  • Cc: Coq Club <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] Take a proof of a true proposition
  • Date: Thu, 24 Nov 2011 15:35:59 +0400
  • Envelope-from: porton AT yandex.ru
Dear David,
Thanks for your answer, but your answer is not a solution of my problem but a
sly trick: instead of solving my problem you use an already stated fact
P_true.
In order to get a proper solution I reformulate the problem in such a way
that this trick becomes impossible (I hope).
Parameter P: Prop.
Theorem t: P -> True.
proof.
  assume P.
  let X be such that (X : P).
end proof. Qed.
The "let" statement does not work with the error message:
Error: In environment
_hyp : P
X : P
The term "X:P" has type "P" which should be Set, Prop or Type.
How to circumvent this problem? I need an arbitrary proof [X] of an assumed
true proposition.
24.11.2011, 03:02, "David Pichardie"
<david.pichardie AT inria.fr>:
> Hi Victor,
> Here the proof term of the statement "P" is "P_true" itself. Curry Howard
> is behind the curtain.
> If this is really your question then I think it is time to read the Coq Art
> book.
> Regards,
> David.
> Le 23 nov. 2011 à 13:56, Victor Porton a écrit :
>>  We should be able to take a proof of a true proposition. Is it
>> implemented in Coq 8.3.pl2? My native attempt to do this steps on an error.
>>  Parameter P: Prop.
>>  Axiom P_true: P.
>>  Theorem t: True.
>>  proof.
>>  end proof. Qed.
>>  X : P
>>  I hope Coq allows to get around this, but I'm not sure.
>>  Victor Porton - http://portonvictor.org
