- To: Gregory Bush <gbush AT mysck.com>
- Cc: Dimitri Hendriks <diem AT xs4all.nl>, coq-club AT inria.fr
- Subject: Re: [Coq-Club] assuming extensional equality is a congruence relation
- Date: Fri, 25 Nov 2011 10:34:19 -0500
I guess I should use the correct axiom...
Section aa.
Variables (A : Set).
Definition eeq (s t : nat -> A) :=
forall n, s n = t n.
Infix "==" := eeq (at level 75, no associativity).
Axiom funext : forall A B (f g : A -> B), (forall x, f x = g x) -> f = g.
Lemma eeq_congr : forall f s t, s == t -> f s == f t.
unfold eeq.
intros.
assert (s = t).
apply funext in H.
trivial.
destruct H0; trivial.
Qed.
On Nov 25, 2011, at 10:06 AM, Gregory Bush wrote:
Functional extensionality is a common axiom, and assuming it will prove eeq_congr, so I would not be worried it is inconsistent. I suspect a model-theoretic argument is needed to prove eeq_congr is independent. I'll leave that part to the experts.
Section aa.
Axiom funext : forall A B (f g : A -> B) x, f x = g x -> f = g.
unfold eeq.
intros.
assert (s = t).
apply funext with n; trivial.
Qed.
On Nov 25, 2011, at 9:00 AM, Dimitri Hendriks wrote:
Section aa.
Definition shift (s : nat -> A) :=
fun n => s (S n).
Lemma eeq_congr :
forall f s t,
s == t ->
f s == f t.
- [Coq-Club] assuming extensional equality is a congruence relation, Dimitri Hendriks
- Re: [Coq-Club] assuming extensional equality is a congruence relation,
Gregory Bush
- Re: [Coq-Club] assuming extensional equality is a congruence relation, Gregory Bush
- Re: [Coq-Club] assuming extensional equality is a congruence relation, Ralph Matthes
Gregory Bush
