- To: coq-club AT inria.fr
- Subject: [Coq-Club] Induction with type constraints
- Date: Sat, 26 Nov 2011 15:45:25 +0100
Hi All,
I'm trying to do a case analysis over an inductive type where the
allowed constructors are restricted by the type of a term. It
essentially equivalent to the following setup with indexed lists:
Inductive Vect (A : Type) : nat → Type :=
| VNil : Vect A 0
| VCons : forall n : nat, A → Vect A n → Vect A (S n).
Lemma zero_len_is_nil (A : Type) (v : Vect A 0) : v = VNil A.
Proof.
inversion?
induction?
Is it possible to express the fact that this vector of length zero can
only be VNil? I have also tried using a fixpoint. Perhaps some kind
of "match annotations" would help, but I confess I do not completely
understand how to use them.
Fixpoint zero_len_eq (A : Type) (v : Vect A 0) : v = VNil A :=
match v with
| VNil => identity_refl (VNil A)
end.
Any help would be greatly appreciated.
Eric Finster
- [Coq-Club] Induction with type constraints, Eric Finster
- Re: [Coq-Club] Induction with type constraints,
Adam Chlipala
Eric Finster
- Re: [Coq-Club] Induction with type constraints, Adam Chlipala
Benedikt Ahrens
Daniel Schepler
- Re: [Coq-Club] Induction with type constraints, Eric Finster
Daniel Schepler
Eric Finster
Adam Chlipala
