- Cc: Coq Club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] typeclass methods in hints
- Date: Sat, 26 Nov 2011 18:49:33 +0100
Hi,
I support this feature request...
As Michael said, declaring the hint with @ is often not satisfactory
(when possible), since the maximally implicit arguments should usually
be filled by typeclass resolution rather than by (e)auto.
Best,
Damien
2011/11/25 Michael Shulman
<mshulman AT ucsd.edu>:
> Is it possible to declare a typeclass method as a hint? When I say
> Hint Resolve some_method.
> if no instances have yet been declared, I get a "cannot infer implicit
> parameter" error. If some instances have been declared, then
> apparently only the method applied to the first such instance is
> declared as a hint. I can specify which instance I want with
> Hint Resolve (@some_method some_instance).
> but I want the hint to apply to *all* instances. However, if I write
> Hint Resolve @some_method.
> I am told "some_method cannot be used as a hint". Is there a way to do
> this?
> Thanks,
> Mike
- [Coq-Club] typeclass methods in hints, Michael Shulman
- Re: [Coq-Club] typeclass methods in hints, Damien Pous
