- To: Michael Shulman <mshulman AT ucsd.edu>
- Cc: Coq Club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] matching a function application?
- Date: Mon, 28 Nov 2011 08:46:12 -0500
Michael Shulman wrote:
Why does the following match fail?
Theorem test A (f:A -> A -> Type) (a b :A) : f a b.
match goal with
|- context cxt [ ?g ?x ] => idtac g
end.
It looks to me as though the goal contains two subterms of the form (g
x), one where g = f and x = a, and another where g = (f a) and x = b.
Until recently, that example would fail even without the [context] pattern. My guess is that [context] isn't implemented to consider all prefixes of a curried application as separate terms. (The internal representation of terms combines curried applications into single terms, so it takes extra work to get behavior that matches our informal idea of the syntax.)
A standard trick which seems hacky but imposes minimal hassle in practice is to include a pattern for every function arity you want to support.
- [Coq-Club] matching a function application?, Michael Shulman
- Re: [Coq-Club] matching a function application?, Adam Chlipala
Chung-Kil Hur
Alexandre Pilkiewicz
Michael Shulman
- Re: [Coq-Club] matching a function application?, Chung-Kil Hur
- Re: [Coq-Club] matching a function application?, Pierre Letouzey
Michael Shulman
