coq-club - Re: [Coq-Club] Should eauto progress leaving non-instantiated existential variables?
chronological Thread
  • To: Damien Pous <Damien.Pous AT inria.fr>
  • Cc: coq-club <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] Should eauto progress leaving non-instantiated existential variables?
  • Date: Thu, 1 Dec 2011 10:44:27 +0100
2011/11/30 Damien Pous
<Damien.Pous AT inria.fr>:
> I only partly agree on this point:
> - yes, such an interface tool would be great,
> - but there are situations where you want to keep [(e)auto] in the
> source because it's possibly more robust to small changes in the
> definitions.
> (e.g., when you change the order of the hypotheses of some hint, when
> you remove hypotheses of some hint, or when you change the hypotheses
> of the current goal).
> So maybe the interface you want to implement should be able to recall
> that some sequence of lemma applications was found with [(e)auto], so
> that this sequence can easily be recomputed when it breaks.
This is exactly what I have in mind:
replace eauto by:
solve [ <what eauto did> | idtac "Something went wrong here, trying
eauto instead" ; eauto | idtac "even eauto went wrong" ]
And have the interface replacing <what eauto did> by the new tactic
found when necessary.
P.
