- To: Jelle <jelle AT defekt.nl>
- Cc: coq-club AT inria.fr, Andrew Polonsky <andrew.polonsky AT gmail.com>, Maxime.Denes AT inria.fr, Robbert Krebbers <mail AT robbertkrebbers.nl>
- Subject: Re: [Coq-Club] Impredicative Set and Records
- Date: Sun, 04 Dec 2011 14:47:45 -0500
Jelle wrote:
Hello,
When running Coq with "-impredicative-set" I would have expected the
following to work:
Record foo : Set := mkFoo { bar : Set }.
foo is defined
foo_ind is defined
foo_rec is defined
But the projection is not defined:
Warning: bar cannot be defined because it is large and foo is not.
Trying this manually gives:
Definition bar (x : foo) := match x with mkFoo b => b end.
Error: Incorrect elimination of "x" in the inductive type "foo":
the return type has sort "Type" while it should be "Prop" or "Set".
Elimination of an inductive object of sort Set is not allowed on a
predicate in sort Type because strong elimination on non-small
inductive types leads to paradoxes.
What is going on here? -impredicative-set doesn't work with records?
And what exactly is strong elimination?
Strong elimination (usually called large elimination, actually) is a [match] whose result type doesn't have type [Set] or [Prop]. Less formally, it's a [match] returning a type. A large inductive type definition has at least one constructor whose type contains a "polymorphic" [forall], quantifying over types. Your [foo] is certainly one such type, since the type of [mkFoo] includes quantification over [Set].
To preserve consistency, large elimination on large inductive definitions in impredicative [Set] must be disallowed. The details of this I am not familiar with.
- [Coq-Club] Impredicative Set and Records, Jelle
- Re: [Coq-Club] Impredicative Set and Records, Adam Chlipala
- Re: [Coq-Club] Impredicative Set and Records, Gert Smolka
