- To: Marco Servetto <marco.servetto AT gmail.com>
- Cc: coq-club AT inria.fr
- Subject: Re: [Coq-Club] survey on Coq interfaces
- Date: Sun, 4 Dec 2011 20:02:51 +0000
On Sun, Dec 4, 2011 at 7:14 PM, Marco Servetto
wrote:
>>Interesting perspective. I've never heard someone previously say that it's
>>important to be able to
>>"check Coq proofs by hand."
> One good reason to check proofs, or at least, to understand what is
> going on with proofs is
> that is useful for debugging your statements: We know that the
> statements we have proved are right.
> But are we really understanding our statements? is like "requirements
> bug" in software programming.
> See the proof in "action" may help ourselves to understand our statements.
I would suggest that making use of the statements is a better way to
understand them and make sure they are right than stepping through
their proof. For example, if you prove a lemma and that enables you to
prove your main theorem, then it's likely the lemma statement was
correct. If you make a definition and you can subsequently prove lots
of unsurprising "sanity test" results about it, then it's likely the
definition was correct.
- [Coq-Club] survey on Coq interfaces, Aaron Stump
- Re: [Coq-Club] survey on Coq interfaces,
Mihai ANDRIES
Adam Chlipala
Mihai ANDRIES
Adam Chlipala
Marco Servetto
- Re: [Coq-Club] survey on Coq interfaces, Ramana Kumar
- Re: [Coq-Club] survey on Coq interfaces, Marco Servetto
Marco Servetto
Adam Chlipala
Mihai ANDRIES
Adam Chlipala
Mihai ANDRIES
