- To: coq-club AT inria.fr
- Cc: Alexandre Pilkiewicz <alexandre.pilkiewicz AT polytechnique.org>
- Subject: Re: [Coq-Club] induction scheme
- Date: Tue, 6 Dec 2011 11:03:28 +0100
Certainly star_ind and star_ind' have the same proof power. But since
star_ind has the dependency on y, it will give you unnecessarily complex
inductive hypotheses (since the assumptions depending on y will be included).
Gert
Am 06.12.2011 um 10:53 schrieb Alexandre Pilkiewicz:
> I'm sorry, I won't reply to the main question of the email, but I'm
> still going to ask another one:
> On Tue, Dec 6, 2011 at 10:35 AM, Gert Smolka
> <smolka AT ps.uni-saarland.de>
> wrote:
>> The induction scheme star_ind generated by Coq is suboptimal since it
>> quantifies over both arguments x and y of star. It is easy to prove an
>> induction scheme quantifying only over x.
> How is it "sub-optimal", since you are able to prove your own
> "induction scheme" with it. It seems to me that since star_ind implies
> your star_ind', it is more optimal than star_ind'!
> Do you have an example of lemma that you think you'll be able to prove
> with star_ind' and not with star_ind?
> Goal forall x y z, star x y -> star y z -> star x z.
> Proof.
> intros * H *.
> induction H; eauto using starS.
> Qed.
> Cheers,
> Alexandre
>> Lemma star_ind' (y : X) (p : X -> Prop) :
>> p y ->
>> ( forall x x', r x x' -> star x' y -> p x' -> p x) ->
>> forall x, star x y -> p x.
>> Proof. intros A B x C. induction C ; eauto. Qed.
>> Unfortunately, I cannot use star_ind' with the induction tactic:
>> Proof. intros x y z A. revert z.
>> induction A using star_ind'.
>> Error: Cannot recognize the conclusion of an induction scheme.
>> I have 2 questions:
>> 1) Why does the induction tactic reject star_ind'?
>> 2) Is there a good reason that Coq generates star_ind rather than
>> star_ind'?
>> Thanks, Gert
- [Coq-Club] induction scheme, Gert Smolka
- Re: [Coq-Club] induction scheme,
- Re: [Coq-Club] induction scheme, Gert Smolka
Cédric AUGER
Gert Smolka
Gyesik Lee
- Re: [Coq-Club] induction scheme, AUGER Cédric
Gyesik Lee
Gert Smolka
- Re: [Coq-Club] induction scheme, Adam Chlipala
- Re: [Coq-Club] induction scheme, Tom Prince
