- To: Ben Horsfall <ben.horsfall AT gmail.com>
- Cc: Coq Club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Closed under intersection
- Date: Thu, 08 Dec 2011 10:01:50 +0000
- Organization: Radboud Universiteit Nijmegen
Ben Horsfall wrote:
I've been trying to prove something which ought to be able to be done by a
straightforward induction: that if a set of sets is closed under
intersection, then it has a least element (under ordering by set inclusion),
viz. the intersection of all of its elements. I have tried *many* variations,
including (co)inductive ones -- a simple non-inductive formulation is below.
It's easy to show that the intersection of all elements is included in every
element, but I can't show that it is an element. From a practical point of
view, I can't see how to define the generalized intersection in such a way
that it can be unified with an Intersection term.
Ben,
I think Arnaud's answer nails it, but for more details (and historical interest), please see the attached LEGO file from 1992.
The concept you are after is in Paul Cohn's "Universal Algebra" (1965), the idea of an *intersection-closed* family of sets:
F is intersection-closed iff forall G \subseteq F, F(\bigcap G)
(so trivially, F(\bigcap F)). IC-families have nice closure properties, but for most applications in CS, the observation that for monotone phi, the family
fn C => phi C \subseteq C
is IC, is pretty much all you need for Knaster-Tarski and related results (intersections of jointly commutative families of monotone operators, a la Andrews 1973).
Cheers,
James McKinna
I'm sure I have a blind spot here. Any advice would be appreciated.
Ben
Require Export Coq.Sets.Ensembles.
Definition intersections {A} (US : Ensemble (Ensemble A)) : Ensemble A :=
fun (x : A) => forall U : Ensemble A, In (Ensemble A) US U -> In A U x.
Definition closed_under_intersection {A} (US : Ensemble (Ensemble A)) : Prop
forall U V : Ensemble A,
In (Ensemble A) US U -> In (Ensemble A) US V ->
In (Ensemble A) US (Intersection A U V).
Lemma closed_under_intersection_least :
forall {A} (US : Ensemble (Ensemble A)),
closed_under_intersection US ->
exists X, In (Ensemble A) US X /\
forall Y, In (Ensemble A) US Y -> Included A X Y.
Proof.
intros. exists (intersections US). split.
admit. (**** In (Ensemble A) US (intersections US) ****)
intros. unfold Included. intros. apply H1. apply H0.
Qed.
- [Coq-Club] Closed under intersection, Ben Horsfall
- Re: [Coq-Club] Closed under intersection, Arnaud Spiwack
- Re: [Coq-Club] Closed under intersection, Alexandre Pilkiewicz
- Re: [Coq-Club] Closed under intersection, James McKinna
